GPU bracket purely for displaying card on a shelf?
X55
Hi,
I have an older, non-functioning card that I would like to put up on a shelf. Due to the cooler design it doesn't stand on it's own. Are there brackets out there that are just for displaying a card? Best thing I could find are vertical mounting brackets including riser cables, but those are quite expensive since I don't need an actual cable.
Thanks a lot.
