KFA2/GALAX RTX 3070 RGB Problem!
Gregory Kleanthous
Hello everyone, recently I have decided that I want to upgrade my gpu because of the new upcoming games so I changed from gtx 1660 and put my new KFA2 rtx3070. So far so good with this card temps and fps are perfect with no problems regarding performance. The problem is that the fans(3) are not changing colors even though they are rgb and they can be controlled through xtreme tuner program which I have downloaded and all options for rgb are not clickable. When I first booted my pc after the upgrade it changed colors I think for a matter of seconds in a cycle mode but after that it stayed in a yellowish-green color. Since then the gpu fans are currently locked in that color and I tried almost everything to fix it but nothing worked. Could this be a bad connection when I installed the card or is it some kind of motherboard limitation? every other rgb hardware in my system including motherboard and ram are doing perfect with rgb,
pc specs:
i5-9400f (will upgrade in future)
z390 gaming x
ram ddr4 (4x8) trident z neo
psu is corsair tx750m
any help will be appreciated!
