Looking to build a PC that is going to be stellar for programming/
Solved by trag1c,
15 hours ago, just_dave said:i might be wrong but isn't macOS the best OS for coding?
It's a pretty big mix as it really depends on what you're doing as well as personal preference. I generally prefer Linux as an OS but I like to do my development in Windows for the simple fact that Visual Studio exists...
22 minutes ago, Davejones said:Thank you, that is a good idea. It probably is a good idea to dump more of my money into the CPU, fast storage and ram since I still have a decent GPU.
1 hour ago, just_dave said:In that case I suggest you go full steam ahead and get R9 5950X, 32GB of 3600MHz RAM and maybe 2 or 4TB of NVMe storage. The GPU should be fine for 1440p.
I have to agree with this. For development you can never go wrong with more cores and RAM.
