Power supply
Solved by aDoomGuy,
7 minutes ago, ItsJakeJucie said:and after like 4 weeks it just blew up do all power supply's do this?
Uhhm.. no..? lol
Budget? See if the Corsair RMx or even RM is within your budget. Is good PSU but if it's too expensive... the CM Master Watt wont blow up ..unless.. you fill it with tnt *shrug*
