Internet speed slower on ethernet?
TheJedi
Hey guys.
I just built my new Gaming Rig.
It had a B550 Gaming Carbon WiFi.
When I connected it to ethernet and ran a speed test, I got peak speeds of 180mbps down.
When I connected to WiFi using the onboard WiFi 6 controller, I got speeds of 380mbps.
I ran the test twice, using Ookla's speedtest Windows client.
Anyone know why this is and how it can be fixed?
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
Do you have the latest Lan drivers installed?
Is the PC connected directly to the router or are there other devices like Switches or Powerline in between?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
what link speed is the cable running at?
-sigh- feeling like I'm being too negative lately
Yes latest drivers straight from the motherboards download page.
I have a router from my ISP running in modem mode. I use a Netgear Orbi plugged into that via ethernet
System
CPU: Ryzen 5 3600
Do you mean the download speed or category?
System
CPU: Ryzen 5 3600
the "speed"
Just now, Moonzy said:
the "speed"
Oh, umm not sure. I will check in a minute
System
CPU: Ryzen 5 3600
29 minutes ago, Moonzy said:
the "speed"
Ok so this is what it says
System
CPU: Ryzen 5 3600
weird, but the "speed" may not be accurate as sometimes it might just crap out if u try to go anywhere near it (personal experience)
tried shorter/other cable?
Yeh I tried a 5m Cat 6 cable and the one I've got plugged in right now is a 15m Cat 7
System
CPU: Ryzen 5 3600
check your router/switch, some ports are rated at different speeds
Before I changed pc, I was using a 7yr desktop from hp. It was plugged into the same port and wire and it got the same 380mbps as wifi
System
CPU: Ryzen 5 3600
then you should try reinstalling the latest drivers from motherboard's website
or if you're using expansion card, the latest driver for that
I will, I only installed them 2 days ago. Should I try it from the realtek website instead?
System
CPU: Ryzen 5 3600
u could, or try emailing the board manufacturer
Ok, so I just ran a speed test again before installing the drivers. The Download speed has fixed itself. But the upload is a 12 when it should be somewhere in the 30s? I will try re-installing the drivers and let you know what happens
System
CPU: Ryzen 5 3600
ok, reinstalled the drivers from realteks site. Fixed now.
System
CPU: Ryzen 5 3600
