Search In
  • More options...
Find results that contain...
Find results in...
6800XT Coil whine
I've heard one or two reviewers mention it but they seemed to imply it is only auditable when playing games at 140+fps. However Im getting it at all frames, the more frames there are the higher the pitch.
Is anyone else experiencing that much coil whine?
Coil whine can occur under any load, certain loads are more likely to have coil whine worst/if present, such as high fps in game menus.
If it's bad enough you might be able to rma it, but usually the response is along the lines of "it's fine, live with it"
desktop
r5 3600 wip, 4.2ghz@1.25v (1.212 get) [3.7GHz@1.0125v(0.975v get) on air, nh-l9x65] | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000 cl15@3733 cl14|Zotac 2060 amp wip [1965mhz@900mv on air] | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG | Silverstone ML08
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Newegg
