Ryzen 5800x & Aorus x570 Mobo
Solved by Rooked,
It is not required since you probably have a discrete GPU. APU drivers are only needed when you have CPU's with integrated GPU's and you don't have a discrete GPU.
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
2
RagePoweredGamer ·
Posted in Troubleshooting16 -
14
Cookiey ·
brau508 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
