Monitor is it Worth it?
Royal Stank
So recently I bought a gaming laptop https://www.costco.com/msi-gf75-thin-gaming-laptop---10th-gen-intel-core-i5-10300h---geforce-gtx-1650ti---144hz-1080p-display.product.100684897.html
and was thinking of getting a ASUS - TUF Gaming VG249Q 144Hz 23.8” IPS LCD FHD 1ms FreeSync Gaming Monitor to play with. I wanna know if this monitor is worth it.
depends on the game. since you are considering high refresh rate, i am guessing that you are playing esports titles. You should be able to hit over 100 frames so sure go for it.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Let's say that i'm playing Destiny 2 or something like Planetside 2. How smooth will the FPS be?
i don't know. just boot up the game and take a look.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
