help Want USB C 3.1 Gen 2 connector to go to the front of my case with a B550M VDH WIFI PRO
Solved by dilpickle,
3 minutes ago, Menazeen said:Yeah I can imagine, there aren't any expansion cards like that for PCIE x1. So generally there is no way to get a larger data transfer rate than the one your motherboard supports, right?
No. Expansion cards are the only way and as you've found there aren't any for PCI-E x1.
