LG 32GK650F + DP cable + 1080Ti -> display settings questions
Solved by Glenwing,
3 hours ago, koko_1989 said:Hi all,
I have only recently discovered that chroma subsampling is a thing : D
And when I found out that 4:4:4 is supposed to be the best on a main PC display with lots of text I wanted to try it.
No, RGB is the best.
YCbCr 4:4:4 is the best out of the YCbCr modes because it doesn't use subsampling, but still uses limited range which slightly reduces color depth (for historical technical reasons).
Always use RGB for PC displays. YCbCr is used for TVs.
