Why do I need Usb Type C on my motherboard ?
Solved by Arika S,
there are numerous type-c to type-c devices.
Think external SSDs
Pen displays
USB Hubs if you need more ports (type-c usually has a higher throughput)
it could be a thunderbolt port and therefore compatible with thunderbolt devices.
you don't "need" type-c, but it's better to have it and not need it than not have it when you do need it.
QuoteWould I be able to transfer files from one computer to another if I plug the Type - C on the motherboard and the Type-A on another computer?
no
