Difference between JEDEC and RAM Manufacturer
Solved by Cyracus,
3 minutes ago, porina said:I'll have to try a recent version of thaiphoon burner as I don't remember seeing that before
in the report function.
I have Micron E-die, Jedec raw...: SK hynix. So you probably have B-die, as said look up the part number. Searching k4a8g085wb-bcrc shows up samsung dram chips
Maki Zenko ·
Posted in General Discussion2 -
3
1
FlpDaMattress ·
Posted in Servers, NAS, and Home Lab3 -
10
6
OhYou_ ·
Posted in Peripherals0 -
SpaceOperator ·
Posted in Storage Devices10 -
DaMegaTaco ·
Posted in Troubleshooting0 -
14
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
