I can't get Logitech G Hub audio visualizer to work! Help!
Dep96
I recently bought a Logitech G513 as my first mechanical keyboard and was excited to try out the audio visualizer feature. I haven't altered anything and nothing happens! I'm trying to get it to work with a youtube video. I'm using headphones and my system volume is set to 8. Can someone help me?
Just select the Preset and change it to Audio Visualizer, works fine for me.
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 10 Pro
-> Moved to Peripherals
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
That's exactly what I did and it doesn't work.
  • 3 weeks later...
I have the same issue. I know I'm doing it right because it works perfectly fine on my laptop. On my desktop, nothing, it's just black.
Edit: Made it work. I was looking at the audio output properties to see what was configured differently between my laptop and desktop. Disabled "Enable audio enhancements" under advanced and now the visualization works.
  • 1 month later...
thank you man, you just saved my day lmao
