What case fans should I get?
neohazardous
Its my first pc build and Im not so sure what kind of case fans I should get that would best fit what I want. I have a fractal meshify c case and a gigabyte x570 aorus elite wifi motherboard. Im using fan cooling for the cpu. I wanted to have 3 rgb 120mm fans for the front panel. And then upgrade the stock rear fan to an rgb fan at a later date. What recommendations do you have for me to get? These fans are the last things I need to get for my build and Im really not sure what I should get, or if Ill need adapters or extra wires to hook it all up.
