Search In
  • More options...
Find results that contain...
Find results in...
3D Workstation upgrade, Help with Motherboard and cooling
Budget (including currency): 1000 USD
Country:  USA
Games, programs or workloads that it will be used for: 3D work, Zbrush, Marmoset, Unreal
Hello,
I'm looking to do an upgrade to my existing build. I don't game on the PC almost at all, it's primarily used as a 3D workstation. The aim so to upgrade the necessary parts without spending a ton of money on it, not sure if the GPU is important as it's not the focus of the build, but I have a 1050ti and will be keeping that for now.
This is the parts list I put together:
PCPartPicker Part List: https://pcpartpicker.com/list/CLtCrr
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($479.99 @ B&H)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($169.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($63.99 @ Amazon)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($59.99 @ Newegg)
Total: $833.95
Generated by PCPartPicker 2020-11-27 18:10 EST-0500
I'm not sure about the cooling and the motherboard. I need cooling that will cool the CPU nicely, and the motherboard needs to be good enough to support the CPU. I don't plan on overclocking, and the motherboard doesn't need Wi-fi, i chose that one because it was one of the better priced options. Thanks for your suggestions!
