Ethernet on my pc is 300 Mbps slower than wifi on my phone
icanreadtv12321
I just got internet at my new house and I am paying for 400Mbps download speeds, My pc only gets up to about 90 Mbps and my Phone gets to like 460 Mbps. What could be causing this? My pc is connected via ethernet also.
I'd wager you're connected at 100Mbps on the ethernet port either due to a bad cable or a port on the connected device being limited to 100Mbps. What make/model device is your PC connected to?
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Check at what speed the wired connection is running. Could be that it isn't recieving a gigabit signal and only running on 10/100mb
Its a cat 5e cable
best guesses are either a device along the way is limited to 100Mbps, or a cable is damaged. (100Mbps uses two pairs in the ethernet cable, gigabit uses all four pairs)
Just now, icanreadtv12321 said:
Its a cat 5e cable
Go to your network adapter and check what speed it is running at.
The router is a Sagemcom fast 5260 and the modem is a brand new modem from spectrum
how do I see what its running at? im in device manager
Control Panel\Network and Internet\Network Connections
Right click on the Ethernet connection and click Status and look for Speed
Prior Build Log/PC:
Settings->Network and internet->change adapter settings (the text it is a button)->Right click on whichever one is labelled ethernet-> status and there you'll see the speed
it says 1.0 Gbps
it says 1.0 Gbps
it says 1.0 Gbps
Do you have any motherboard software such as Killer software that might be doing QoS or anything?
Prior Build Log/PC:
The only thing I can think of is Aura
