Where to connect the Fans?
Solved by KageSong,
Okay, so here's some color coded lines. The one with a question mark, I'm really not sure. The rest I'm fairly confident about, but you should probably wait for someone who knows the last one. Sorry. I would guess that your cpu_opt plug has an option in the BIOS to set it as aio_pump, as I don't see one labeled as such in the manual for your motherboard. I hope this helps at least a little bit. Good thing I'm not paid to do this (B
