Rgb fans compatibility
Fastboi
I am going to build my first pc, but there is one thing that i don't understand, my case is going to be the msi mag force 100r which comes with 3 fans (2xrgb,1xnormal) how do I know if I can connect those fans to the following motherboard MSI B450M-A PRO MAX and also use the addressable rgb functionality to its fullest
that mb dose not have any rgb /argb headers. you got to spend a bit more.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
