PC Won't Power in After Moving it to new chassis
Solved by VietKing,
14 hours ago, VietKing said:Got a new case for my pc. Moved it into it and now when I press the power switch nothing happens. The debug light, lights up for a millisecond under Dram, GPU, and Boot drive. But nothing turns on and it only does the debug light once before I have to unplug it for it to do it again. Everything worked fine when I had it in the old case this morning
Okay found the problem. One of the PSU cables was from a different PSU and didn't work with this one. Removed the cable and it worked
