Search In
  • More options...
Find results that contain...
Find results in...
Using Galaxy Tab S7 Plus as single monitor for PC?
Is it possible by any means to be able to use the Tab as a primary PC monitor? I know I can just go get a monitor but there are no monitors out there besides those huge TV sized ones that have an OLED screen, decent motion handling, not too huge, and has high refresh rate (120Hz and above). I can even use the Tab as my laptop too and make use of it as a PC monitor when available. I know it is possible to connect the Tab to another device to act as a secondary monitor but what about if I only want to have one display on being the Tab?
https://www.neweggbusiness.com/smartbuyer/over-easy/how-to-use-your-tablet-as-a-second-monitor/
Spacedesk is also a similar app.
I have never used any of those software before.
I don't have a Tab S7.
I have never attempted, and have no interest in using a tablet as a monitor.
I wouldn't expect it work for framerate in excess of 60fps.
Good luck.
Awareness is key. Never enough, even in the face of futility. Speak the truth as if you may never get to say it again. This world is full of ugly. Change it they say. The only way is to reveal the ugly. To change the truth you must first acknowledge it. Never pretend it isn't there. Never bend the knee.
Please quote my post in your reply, so that I will be notified and can respond to it. Thanks.
