Ryzen 7 2700 core clocks won't move beyond base clock speeds
15 hours ago, Gdolike said:Thank you for your reply as it is rare to receive one as it seems.
So do you mean that having a constant clock speed for all the cores in idle, in game, and in a stress test, while having the same GHz is normal.
Then I just don't understand why I have all these "boosts" and why in a game like Dota 2 I have like 90 fps. I had similar results with a i5 6400 which had less cores and the clocks were much slower...... Anyways I took some r20 cinebench tests the other day and my results were lower to results in this website https://www.cgdirector.com/cinebench-r20-scores-updated-results/
Is this also normal?:)
The boosting system is fairly complicated in this chips, but generally with CPB2, it boosts when it can, as much as it can. It depends on a lot of factors including motherboard, PBO status, and your individual piece of silicon.
Zen+ only reduces clock speeds when nothing is going on, the preferred power-saving mechanism is through putting the cores to sleep, while keeping clock rates high. This gives a more responsive and efficient CPU.
You are guaranteed to get 3.2 GHz all-core load (provided a compatible motherboard), and you are getting that.
Benchmarks require care and effort in taking, to provide compareable results. It's very possible that windows was doing something in the background, or other programs. As I said before, it also usually scales if you drop the temperature below 60°C. Memory speed also plays an impact on Cinebench, and Zen+ in general.
