can you use noctua low noise adapter with NZXT X61
YSL_know_plug
hey folks,
I just wanted to know if you can use the Noctua Low Noise adapter with the NZXT X61 stock fans? The fans are really good even at lowest rpm they perform really well and because of the rubber mounts they dont produce vibrations, but they are bit too loud for my taste at the lowest possible speeds so i wanted to know if its okay to use noctua low noise adapters with those fans? I dont mind getting 2-4°C more on the liquid temp.
thanks for the help!
17 minutes ago, YSL_know_plug said:
hey folks,
I don't see why not. It's most likely just an in line resistor like most other low noise adapters. There's no special logic inside of that adapter.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
ok thanks
