Asus PG279Q Power Issue?
Yakusoku
Hello!
Long story short. I turned on my system like normal several hours ago. Monitor works fine. I shut down the system and the monitor with it goes to sleep/power off.
Came back from work to play some games, boot my system and notice my main monitor the PG279Q didn't turn on as usual.
I did what troubleshooting I can. Since I have its older brother the PG278Q which has the same power brick, I tried using it on the PG279Q no dice. I then tried using the PG279Q's brick on the PG278Q, works and no issues. So its not a power brick issue.
Just wanted to ask if there is a way to troubleshoot this issue. And a possible solution.
Please and Thank You!
This may sound crazy, but it has worked for me in the past on more than one occasion. Might not solve your issue either but there is no harm in trying.
But sometimes capacitors get overloaded. And it can cause no display issues. The 'fix' is to unplug the power from the display, and then hold the power button for like 10 seconds. It drains any voltage left from the capacitors and therefor negates the no display issue because of capacitor overload.
Give it a go. If that does not solve your issue then ignore my crazy ramblings haha.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Update.
Woke up, the red led on its base still dead.
Decided to re plug the power cord.
It turned the thing back on!?
Went and took a shower, came back turned on rig. The monitor is alive, restarted and its still working like always.
Replugged the power chord(the one that's connected to the monitor) multiple times it's good(?)
Headed to work so i hope it's fine when I get back.
Anyone know what caused/is causing this?
  • 1 year later...
On 11/25/2020 at 5:23 PM, Yakusoku said:
Update.
Good day genglemen. I know it's been a long time since you originaly posted this, but seeing that TONS of people have these power problems, and there is literally no info online,I thought I'd share what I know. NOTE: I am no expert in fixing these monitors and I only did it for myself and my friends, this is just a temporary fix and will not completely solve the issue, a dying monitor is a dying monitor.
So these monitors tend to just randomly die at the end of their warranty - no repairs - any very costly. By analyzing couple of Asus ROG monitors with similar symptoms I found out that most of them had literally no power issues -- if you start tracing the power you will see that all voltages are present, both the panel and motherboard test just fine (no shorts and resistance values ok) and if you test the buttons you will see that they are working just fine. So what's the problem? There are mainly 2 things that could cause these monitors to not start, 1.the startup chip 2.the g-sync processor on the g-sync expansion card. Let's talk about the startup chip first (I am writing this from work so I can't recall the chip number and exact location, but you will find it on the motherboard besides the slot where button flex cable is plugged). Inspect it visually, check for pin bridges or obvious damage. Most of the times, this was the failing or failed component so if you find a datasheet you can check if the PWR_ON signal is present - if not, replace the chip.
The second issue could be the g-sync processor and its crappy termal paste (not because of its bad cooling properties but because of its quality. Most of the times, these processors run very hot and when the termal paste degrades over time it tend to liquify and leak around the processor, messing up the surrounding components -- sometimes going under the processor itself and creating chaos under it). Thoroughly clean up the surrounding components with rubbing alcohol/zippo lighter fuel and a toothbrush, then reflow the cpu with hot air gun and then clean it up again. Clean up the old thermal paste and apply a new one--reassembly the monitor and test if it works. By now, the monitor should power on normally, and if you somehow manage to keep it from completely losing power (plugging it into the UPS), it will keep on working as long as you dont unplug it from the power source. Cheers
