Ram not running at advertised speeds
MiruIsBadAtPcs
Go to solution Solved by -rascal-,
47 minutes ago, MiruIsBadAtPcs said:
Hey! Here is the screenshot.
Not the correct tab.
'SPD' just reading what is flashed into the RAM profile.
Check the 'Memory' tab.
DDR4-3200 should say DRAM Frequency: 1600 MHz.
Hey guys! So i just upgraded my ram since mine was very bad. I purchasedd 16 gb of ddr4 ram,3200 mhz, more exactly corsair vengeance pro rgb. I have enabled A-XMP but in the bios and in cpu-z it still says my max ram frequency is 2133. I dont really know what to do since im pretty bad at computers and i was wondering if you guys could help me!
Where does it say that its running 2133
Any Help is appricated! Please correct me if I´m wrong!
Sorry for grammer/spelling mistakes, but english is not my native language (it´s german in case you were curious) *expand to see builds*
Primary PC: CPU: AMD Ryzen 5 3600 | GPU: Crossfire Radeon 6870 + 6850 | RAM: CORSAIR Vengeance 2X16 = 32GB @ 3600MHZ DDR4 | MOBO: ASUS ROG STRIX B450-F | COOLER: COOLER MASTER ML360R | CASE: DEEPCOOL Matrexx 55 V3 ADD-RGB | PSU: GIGABYTE P850GM 80+ GOLD | SDD: CRUCIAL MX500 250GB |
Everything thats not colourful I haven't bought yet.
Secondary PC(Currently not operational): CPU:  INTEL Q8200S @ 2.33Ghz | GPU: GTX 750 ti / 760 | RAM: 4X2 = 8GB @ 800MHZ DDR2 OCZ Platinum | MOBO: ASUS P5E-VM SE | COOLER: Be Quiet! Silent Loop 280* | CASE: DEEPCOOL Matrexx 55 V3 ADD-RGB* | PSU: CORSAIR RM850 2019 80+ GOLD* | SSD: CRUCIAL MX500 250GB*
Everything marked with * is what I bought for the Primary PC and I'm just using it until I get all the parts.
You need to go to your BIOS and change it there is a profiles tab on the BIOS that once you choose the profile 1 ussually there's only one and there you go
In which tab does it say that? a picture would be helpful. I'm a little confused, because for me it says the half of the actual speed, that's because ram is DDR (DOUBLE Data Rate), but CPU-Z just shows the max bandwidth. So it has to doubled to get the actual max speed.
I have two profiles and i tried both of them but they dont seem to change anything
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Silly me! On the memory tab it does infact say 1600 mhz. Id guess that means that its running at 3200 mhz. Rookie mistakes i guess :)
