i7 4790k won't go over 4.4Ghz, even when multiplier is greater than 44
Solved by Zhnz,
2 hours ago, unclewebb said:If this works, do a search for mcupdate in C:\Windows.
Windows saves multiple versions of this file. You might be able to find a microcde file somewhere between 7 and 27.
I just tried if it works with rev 7 and it still woudn't apply the multiplier. Then I just reflashed literally the same BIOS version and now it works Thanks for all your help ^^
