DRAM frequency not correct. CPU-Z showing 1599.1mhz on 3200mhz DDR4 (2x8) sticks
Solved by minibois,
TL;DR: your memory is running fine, it's running at 3200Mhz
The SPD tab just shows the JEDEC speeds, which are the default speeds (for DDR4). The memory tab actually shows the actual speeds which is 1599Mhz.
DDR = Dual Data Rate.
A Hz is a tick, DDR memory transfer up and down every tick, meaning 1600Mhz = 3200MT/s. Millions of transfers.
Motherboard and memory manufacturers for that reason call it 3200Mhz, but something like CPU-Z or Task Manager show it correctly, at (roughly) 1600Mhz.
The SPD tab just shows the default speeds the memory can use and the associated timings, i.e. 1600Mhz, 1.35v.
