Are these fans any good for Rad ? NB-eLoop
7 hours ago, gh0st47 said:Hmm actually strictly for aesthetic purpose. I'm planning on getting some of these NB-eLoop as my Case Intake / Exhaust fans as well...they will be able to work as Case Fans too right ?
But how do you tell that these fans are meant for Push only ( for Rad / Tower cooling ) ? Is it because the fan design ?
Also do you suggest that I use the Stock fans for the Arctic LFII 360mm ?
Yep, they work as case fans as well.
The fan can be substantially noisier and the blades are raised and can scrape the rad when mounted in pull. If this can be avoided, they can still perform very well in push / pull. A 120mm rubber grommet may work to space the fan away without introducing too much of a gap between the fan and rad.
If it works aesthetically, you could use the NB-eLoops in push with the stock P12's in pull.
