Hey, i need help with installing arch linux
Go to solution Solved by yoge67855,
I did it using
Well, im trying to install arch linux.
I tried EZARCHER, ARCHFI.
And i want to try the anarchy.
Is anarchy good solution to install arch linux?
not really, i've had tons of issues with Anarchy Linux.
but if you are a noob to this just start of with Manjaro. you get all the advantages of Arch, mainly the AUR but without the pain in the butt of actually getting Arch installed.
She/Her
i just installed Manjarno its really bad
Last I knew, Anarchy setup third party repos. I personally don't recommend the use of third party installers, and if you mention it to the Arch Community you may not get any support.
Part of running Arch is knowing what is installed on your system and how it's configured. I recommend following the official Installation Guide, https://wiki.archlinux.org/index.php/Installation_guide
You can however refer to here for Arch Based Distros / Installers. Just keep in mind the warning at the top of the page.
https://wiki.archlinux.org/index.php/Arch-based_distributions
If you need something simple to setup, Manjaro does a fairly decent job of pre-configuring a Arch based Environment and has community support.
2 minutes ago, Nayr438 said:
From the same page.
ok im gonna use other websites like reddit to get help
8 minutes ago, yoge67855 said:
yeah i know i tried it... i was doing it for 7 hours and at final step was error (i needed to start again)
You shouldn't need to restart the install process. Rather than jumping onto a installer, you would probably be better off sharing what error you ran into.
i dont saved it
which version?
gnome,kde or xfce?
if it was useful give it a like :) btw if your into linux pay a visit here
36 minutes ago, yoge67855 said:
kde
i suggest manjaro xfce if you want to try arch based distros
i want to try arch
Just now, yoge67855 said:
i want to try arch
what feather of arch do you want to test?
the official arch installed with easy installer
well there is a huge meme in linux community about how arch is an abomination to instal
and there is no such thing as "official" in linux
the correct term to use is "normal"
youre right
I actually decided it was time to tackle Arch yesterday, It took me a good 6 hours in total but that's mostly because I started in VMWare and took regular snapshots plus getting VMWare Tools running is a PITA.
I used to official guide linked to earlier in the thread, didn't really encounter anything that caused issue.
Once I figured out the process I moved onto bare metal and if anything it was easier, I got KDE Plasma installed and also a community repo of MESA-GIT for the latest version of AMDGPU with OpenGL & Vulkan. Had a few small issues, Discover wouldn't show any packages (missing dependency) and MESA-GIT wouldn't actually install until I manually removed Clang.
I'd say it probably took me 2 hours to install Arch on my PC, install Plasma, fix the missing dependency and get MESA-GIT running. Not bad for my first time ever.
edit - Oh yeah, the damn keyboard layout. I wasted 30 minutes trying to get an X11 config file to load the correct keymap only to discover you can change it from Settings in about 5 seconds :D
Main Rig:-
Server:-
Just some advice. Don't use Discover, it doesn't handle optional dependencies, If you want a Graphical Package Manager, I would look at pamac-aur which is in the AUR / Chaotic-AUR. Otherwise you might end up in a situation where you install something and it's missing various functionality.
Mesa-Git can be iffy at times, Id recommend Mesa-TKG-GIt over it.
If you need opencl support on amd, I would look at opencl-amd, which is in the AUR and Chaotic-AUR.
If you plan to game with Proton and Wine, you might check out what I posted here
Yeah, I found a guide from Foss with 7 essential tweaks to make on a base Arch install, Pamac is one of them. I also intend to check out Conky & Stacer and do some customisation as well.
Thanks, I'll check that out today. The official Arch Wiki suggested Mesa-Git which is why I went with it. I do some video editing occasionally (Kdenlive looks great BTW), not sure if OpenCL is needed for GPU rendering or not?
Steam was going to be the last thing I tackle, I'll be sure to check out your thread when I get to it :)
Main Rig:-
Server:-
