EVGA 3080 XC3 Ultra Running Hot!
Solved by Mateyyy,
6 minutes ago, Pikatchu said:Its vertically mounted using Cable mod's adapter. It sits reasonably far away from the glass panel.
Would the Lian Li Lancool 2 be fine? or is it a bit worst than the mesh? I am looking to buy my case from Microcenter, and currently the mesh is not in stock.
The Mesh is significantly better in terms of its cooling performance.
