Can I add a water block on a 3090 Founders Edition??
Budget (including currency): Stark Level USD
Country: USA
Games, programs or workloads that it will be used for: evee-thang from gaming to photography/videography, day trading, etc.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm going for as many monitors as possible, with two for gaming/streaming..
So, prob a no brainer, I'm looking to get a 3090 24gb card & I was wondering whether there were liquid cooling solutions for the founders edition, considering the size of the actual board is all wonky looking! OR should I wait until 1st quarter 2021 to try to knab a GeForce 3090 that will have a block of its size & may be cheaper most likely?? (I'm new to this & a little rusty on my build research stuff) As well I plan on getting 2, to SLI for additional hdmi ports. Appreciate any & all input!! Thanks in advance peoples!
( ͡° ͜ʖ ͡°)
Sure.  EK, Corsair, gigabyte, and bitspower all sell them.  How many of them are actually the same one I don’t know.  Corsair is traditionally rebranded EK.
