is 1 gygbite eaternet faster then wifi
Julian D
It's faster in the sense there are fewer fluctuations since it'll be a wired connection rather than a wireless broadcast connection.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
WiFi 6 technically supports faster transfer rates than 1gbit, however, this requires both a WiFi 6 compatible access point and a device with a WiFi 6 chipset / antenna. Additionally, due to how the laws of physics cause WiFi to never be perfect in the real world, a wired ethernet connection will continue being the more reliable option.
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
22 minutes ago, Julian D said:
1 gygbite eaternet
1Gb ethernet is faster than most WiFi but also your internet connection is probably the speed limit here. I doubt you're getting a full gigabit to your house, probably close to 100Mb download and 20Mb upload.
Also, mind the difference between GB and Gb. Big B is Byte, small b is bit. 8 bits in a Byte, so 1GB is quite a lot larger than 1Gb.
And then there's the world of KiB, a Kibibyte! 1024 bytes, with a Gibibyte, GiB, being 1024 KiB.
but to simplify things, most of the time you use lowercase b when talking about data transfer speeds (SATA, WiFi, etc.) and uppercase B when talking about capacity (Hard drives, SSDs, RAM)
Primary PC:
Not true. Most relatively new devices use WiFi "5", called 802.11ac. It supports theoretical speeds up to 1.3Gbps. Latest WiFi 6 (802.11ax) is much faster.
WiFi 5 also supports faster transfer rates.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Not by today's standards but if reliability is a must you can't beat a solid cable.
Also you could easily get wired equipment faster than Gigabit (10/40/100Gbps).
wasnt there a meme from bit wit that was
asus "gaming" router 250 bucks
or a long boi (ethernaet cable) 3 bucks.
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, Akaso EK7000pro
Dead cameras: Nikion s4000, Canon XTi
Pc's
Dell optiplex 5050 (main) - i5-6500- 20GB ram -500gb samsung 970 evo  500gb WD blue HDD - dvd r/w
HP compaq 8300 prebuilt - Intel i5-3470 - 8GB ram - 500GB HDD - bluray drive
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 4GB ram - 1TB HDD - dual DVD r/w
main laptop acer e5 15 - Intel i3 7th gen - 16GB ram - 1TB HDD - dvd drive
school laptop lenovo 300e chromebook 2nd gen - Intel celeron - 4GB ram - 32GB SSD
audio mac- 2017 apple macbook air A1466 EMC 3178
Any questions? pm me.
#Muricaparrotgang
That is under ideal conditions, and ideal conditions are pretty unlikely. If I sit pretty close to my router I do get the full rated speed that my ISP provides but move to the next room and the speed nearly halves pretty easily, not to mention ping. So unless there is an access point or a router in the room the PC is in, getting 1.3gbps is highly unlikely, not to mention additional factors that can significantly affect speed like the quality of the WiFi card in the device. So in most scenarios an Ethernet cable will be the faster and overall better choice.
