Airpods pro for discord
Solved by DrMacintosh,
Don't listen to the mod. He's net very informed. The Mic in AirPods don't suck and you aren't SoL.
When you're connecting your AirPods to your windows PC, you have to be sure that Windows is correctly identifying the AirPods and is connecting to them fully. I've experienced Windows only connecting part of the functionality of my AirPods and that's when quality becomes unusable.
I recommend removing the device from Windows and then reconnecting them fresh. Then go to your audio devices and select AirPods as the output and the headset function of the AirPods as the input.
