Any way to make white soft tubes look good in an all black case? (first time water cooling)
Depending on where you shine the lights from, the white tubes will take the color of the lights! They will also very likely be the center piece of attention other thatn LEDs burning holes directly into the retinas of viewers (what I mean is deirectly visible LEDs - they shoudln't be).
I can definitely imagine it looking great. I personally like straight runs so I go for 45 and 90 fittings where possible to reduce any possible kinks but that is down to taste. Can make it look almost hardline like.
Not to dissapoint you but I have built a watercooled PC with second hard mid range parts in the past and it felt underwhelming tbh. it is a very bad investment of your money and I think watercooling anythign but the highest end parts is not an option for me any more. I still feel regret towards it and I would never do it again, The only exception I can imagine is doing it for a living going to trade shows where specs are 100% irrelevant because no/one will ever use the machine.
