Posted November 20, 2020 I recently purchased a Dell Optiplex 9010 SFF off of facebook marketplace. I was planning to put a gtx 1050 Ti low-profile in it and do some light gaming. I failed to realize however that it only has a 240w PSU which means it can't supply enough power to the 75w gtx 1050 Ti. Is there a 300w+ PSU that I could get to put in this PC? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 You can just buy a cheap ATX case and a decent 400w+ power supply. I doubt there's going to be anything compatible with that. PC Specs AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME BeQuiet Dark Rock Pro 4 | Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 Author I thought about doing that but all the front panel connectors, audio, USB, etc. are proprietary. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 3 minutes ago, CalebTheCourageous said: I thought about doing that but all the front panel connectors, audio, USB, etc. are proprietary. Are you sure? As long as the power button pins are next to eachother you'll be able to use a standard one. edit: oh weird they are very proprietary PC Specs AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME BeQuiet Dark Rock Pro 4 | Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 Actually I can verify that it will work just fine with the 240w stock PSU, I have a Optiplex with a i7 3770 at work and been running a low profile MSI 1050 Ti for a couple years now. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 Author Really? hmm very interesting. Which optiplex do you have? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 1 minute ago, CalebTheCourageous said: Really? hmm very interesting. Which optiplex do you have? Think it's the same model but not at work right now, gray front panel with 4x USB next to the audio jacks under the slim ODD. But basically the SFF with a i7 3770 and a 240 watt PSU. The 1050 Ti is only powered by the PCI-e slot and it's a 90 watt CPU so the whole system only draws around 200 watts. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 20, 2020 2 hours ago, CalebTheCourageous said: I recently purchased a Dell Optiplex 9010 SFF off of facebook marketplace. I was planning to put a gtx 1050 Ti low-profile in it and do some light gaming. I failed to realize however that it only has a 240w PSU which means it can't supply enough power to the 75w gtx 1050 Ti. Is there a 300w+ PSU that I could get to put in this PC? even under 200w psu will run taht 1050 ti low prfoile fine since the rest of the system uses much under 100w anyway. QUOTE ME FOR ANSWER. Main PC: Spoiler |Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz || Test Rig. Spoiler | Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb || Just Sold Spoiler | i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb || Tier lists for building a PC. Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid. (Also case airflow matter or if you are using Downcraft air cooler) Spoiler Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid. ( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D) Spoiler Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid. (RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units) Spoiler Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money! Spoiler Storage tier List. Tier A for Moving files/ OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good. (With a grain of salt, I use tier C for OS myself) Spoiler Case Tier List. Work In Progress. Most Phanteks airflow series cases already done! Ask me anything Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
