Looking for decent bookshelf speakers for record player for wife
Solved by Dedayog,
Those are great speakers. I looked at the 5" models, sound fantastic.
May want to look at a 5" if you want a little fuller sound, as the 4" woofer is a anemic at times.
kim921 ·
Posted in Build Logs1 -
Dalynx ·
Posted in Storage Devices0 -
Fat Cat11997 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
