5900x only showing 6 Cores - Help!
Solved by .Apex.,
Hold on, you have Game Mode enabled, isn't that supposed to disable one of your CCD's? that's why you're getting half the cores
3
Fluffy411 ·
Posted in Troubleshooting0 -
SumanRao ·
Posted in New Builds and Planning1 -
1
6
ShadowWSK ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
