LOW SCORE ON 3DMARK RTX 3070
Coolboi102
 Share
I get 13,000 points in time spy in 3dmark on my 3070 but it looks like most people get between 14,500 to 15,500 Im using an itx case so my cooling isn't that good my cpu is 3700x and I get up to 75c under load on it and the gpu get to 77c under load is it because of the temp of just a worse card then the others?
7 minutes ago, PleaseHelpMeTroubleshoot said:
Bro look at this! I have no idea what is going on with my PC. I get 7000 and others with my GPU gets 12000 normally.
I think it because the people we compare with have better cpu but I don't know
I get 14K in time spy with i7-4790K
77c seems a bit high, can you check if u get thermal limited?
its may be it since i get better score with undervolt but when i undervolt i get crashes as well so i guess i just need new cooling
Here are my results with a 9900K and Palit RTX 3070 Gaming Pro OC
CPU i5 12600K | CPU Cooler Noctua NH-D15 | Motherboard MSI Pro Z690-A | GPU ASUS ROG Strix RTX 3080 10GB | RAM 32 GB GSkill Trident Z 3200 MHz | Monitor Alienware AW2721D / ASUS TUF Gaming VG34VQL1B | PSU ASUS ROG Strix 850G
Do you use a pcie3 board?
Yes, MSI Z390 Gaming Pro Carbon.I have also added 120 MHz to the core clock and 1000 MHz to the memory. Are you running your card stock or with an OC?
try removing the overclock for everything except the ram and setting your bios to pcie3
I’m pretty sure that my board only has pcie3, only the newer Z490 boards have pcie4.
I think I got around 13000 ish without the OC.
i just checked my clock speed when i ran unigine heaven and i got 2100mhz but in 3dmark i get only 1900 i think the low score is because of that
Have you OCed the memory as well?
if you mean the ram so yes i did i have an amd cpu i havent overclocked anything else
Have you tried the Superposition benchmark?
https://benchmark.unigine.com/superposition
  • 1 year later...
i got 12990 points on my aorus master. this card was mined on nonstop for 18months according to the previous owner (bought it used)
my cpu is a 11700k
both cpu and gpu are stock
 Share
