Anidees RGB fans and PWM control
Solved by LogicalDrm,
For one, you can use any PWM header on mobo, not limited to CPU fan.
Using GPU as source for temperature readings is possible if mobo supports it. But mobo's own software or BIOS might not, so that may need 3rd party software. Saying this as someone whose intakes are using GPU temp as control point.
In reality, its unlikely that your GPU would heat up in a way where CPU wouldn't. I can only think of synthetic loads where that would happen.
I don't recommend using splitters if you are using controller. Better way is to connect CPU fan to controller too. But since that "controller" looks more like hub (no individual fan control), better just have it in some other fan header than CPU one.
