Routing packets to certain ports into a specific WAN and others in the other WAN. (in dual WAN environment)
42 minutes ago, Islam Ghunym said:it should feature built in ADSL modem, Dual WAN of course, different USB applications, have decent QOS.. FQ Cadle or whatever they call it, guest network, traffic monitoring and most importantly a decent built in 4G LTE modem.
I'm not sure anything even exists. It's far easier to find each device separately and combine them. As an example, I don't have an ADSL-modem, but I do have a fiber-modem, which is connected to a PFsense-router. I have a separate 4G LTE - modem that is also connected to the PFsense-router, so there's dual-WAN. I then have a separate WiFi-router in the living-room, because that's where WiFi-connection will be most useful -- it would be far less useful where the PFsense-box is located.
PFsense can be installed on practically any x86 PC. I currently still have an Up Squared 4GB RAM as mine, though I have its beefier replacement waiting on the side.
47 minutes ago, Islam Ghunym said:do u have any budget option for me in your mind that does all of this at acceptable price.
You're kind of wanting options that will cost, no matter how you spin it. Besides which, high-quality networking just simply isn't cheap. I am on a tight budget myself, so I understand and I bought the 4G LTE - modem as used from local nerds and the WiFi-router is also a second-hand item in which I installed OpenWRT -- the original firmware was absolute garbage. Other than buying second-hand, there's not much that can be done and a setup similar to mine will cost you like 400€.
50 minutes ago, Islam Ghunym said:I want to route games' packets
That's a lot more difficult, since you have to know each and every port the game uses. I've never tried such setup, so I don't really have any advice there.
