I bought a 1920x1080 resolution monitor that does 240hz..
nelska
But on testufo it clearly isnt compatible with my gtx960 it red bars the test and claims it cannot vsync. I am trying to figure out what I need to upgrade to to be able to get 240hz per second on the testufo without stuttering or vsync issues. is there any kind of accurate answer here or should i just throw an upgrade in and try it again? thanks. i7 6700
disable Vsyn...
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Just now, Letgomyleghoe said:
disable Vsyn...
i dont think you can?..
should be in your monitor settings or in geforce experience
AMD blackout rig
2 minutes ago, Aereldor said:
Isn't testufo a webpage? How do you use vsync on a webpage?
can upgrade my gpu on this mobo with this cpu? at 500watts. b250pc mate i7 6700
I mean im guessing i need a 4k gpu to run 1080p at 4x the 60hz refresh rate. 240hz.
