Should she upgrade her system
Solved by Noah0302,
You could probably stretch it to a Ryzen 5800x, if she can wait until the B450 BIOS updates release.
Buy the same RAM again, it is fine you can maybe even tweak the timings.
And a Radeon 6800.
This should fit into the budget.
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards0 -
4
john b ·
Posted in Phones and Tablets3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
