Will cheap capture card affect stream quality/fps?
Hello I'm new to streaming. I was wondering, will a cheaper capture card slow down my fps on the gaming computer from slower conversion of the game/stream data?
Here is the capture card im thinking of buying(only need 720p or 1080p  for twitch stream), does the quality matter for affecting fps on the gaming computer, or mess stream up any? thanks!
there are two that look similar, but are different prices, let me know please!
https://www.amazon.com/LEADNOVO-Streaming-Broadcasting-Recording-Camcorders/dp/B089KCSSZQ/ref=pd_lpo_23_t_2/131-4977583-3503626?_encoding=UTF8&pd_rd_i=B089KCSSZQ&pd_rd_r=955cb366-0406-4608-88ae-f84f98096352&pd_rd_w=pYIe6&pd_rd_wg=G9Kx5&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=PYFH4GF0C9NCVBMQ1TK8&psc=1&refRID=PYFH4GF0C9NCVBMQ1TK8
https://www.amazon.com/gp/product/B0897JTDK1/ref=pe_1843280_547769660_em_1p_0_lm
Just use display capture instead of shilling out for a capture card, OBS is very lightweight now especially if you are using a Nvidia GPU and use Nvenc encoding.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
Capture cards are only necessary if you're using a dual capture system or want to stream console gameplay. You cant use a capture card to game/capture from the same computer.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
If it is the same system, all capture cards will slow performance down, you could use a secondary system to stream from so that you don't lose any performance. Anyways 1080p is minimum for streaming so the viewers don't leave the stream from quality. So stream using cpu or gpu encoders unless you can pay for a second system
Yes i have a quad core cpu that i want to use as a streaming pc so as to not lose any fps(trying to achieve 250- 300 in afps without drops). was hoping this would prevent drops.
is it a separate PC? NOT your gaming rig, but will be a dedicated streaming rig?
"Black Out"
Yes sir. I have an extra one so I figured I'd give it a try to keep fps and stream stable. If one of the 50-80$ capture cards is good enough to not slow it down, that is.
Also, from what I was reading, i will put capture card on main rig, then use hdmi from gpu to capture
Edited by newtoofps
the second part about gpu and capture card
Basically:
gpu --> capture card through hdmi in--> monitor through hdmi out
                    v
     system through pcie --> streaming service
The problem is, your monitor will most likely be limited to 60fps output because of the capture card. So even if you want 250-300, you wont see a difference
just to clairfy, my main gaming computer will be limited to the output of the capture card that the second computer is using? or is that just for the stream viewers
