Moving into a property with only 11 Mb/s - UK Help?
Solved by mikestrong88,
I actually work for one of the above named companies. The issue is that open reach look after all the infrastructure other than virgin. So no matter who you go with, it's the same speed as its the exact same lines. Just the bill is a different name.
The only alternative to that is FTTP broadband that only really BT and Zen provide, but that's still pretty rare in the UK. Its more rural areas or brand new builds that are getting it.
If you want to DM me the full address, I'll check my work systems and see what is available for you so I can give you a definitive answer?
