Search In
  • More options...
Find results that contain...
Find results in...
Heyo, bought a new laptop I travel so good purchase by me but its a G5 and it has heating problems so I wanted to change the ghz from 4.4ghz- 4.2ghz to around 3.2ghz
Ofc its dell BIOS btw
You can change certain settings - like how much power the CPU can use - with Intel XTU.
Sorry if my post seemed rude, that is never my intention.
"Why do we suffer a lifetime for a moment of happiness?" - Anonymous
Hmm Is That In The BIOS? (I dont know much bout computer bios stuff xd)
At least in older laptops, there's usually a setting in BIOS for "low frequency" mode to disable turbo boost.
Main: AMD Ryzen 7 1700X, Nvidia GTX 780, 16 GB 2667 MT/s DDR4 Fedora 33 x86_64
Secondary: Intel Xeon X5670, Nvidia GTX 660, 24 GB 1333 MT/s DDR3 Windows 10 Home x86_64
Server: Intel Xeon X5670, 60 GB 1333 MT/s DDR3-R Ubuntu Server 20.04.1 LTS x86_64
Laptop: Intel Core i5-3320M, 16 GB 1600 MT/s DDR3 Fedora 32 x86_64
No, it's just a program you can download on your laptop: https://downloadcenter.intel.com/download/29183/Intel-Extreme-Tuning-Utility-Intel-XTU-
I've personally had good luck with lowering the "Turbo Boost Power Max", keeping an eye on the clockspeed at the bottom of the program.
5 minutes ago, RTX 2070 Max-Q said:
Oh god this is uhh very complex
There is a lot you can do with the program. What I've personally had good luck with was tweaking Turbo Boost and keeping an eye on the max core frequency:
image.png.b8b299148e3f9b02647499fcb9ef5024.pngwow that actually works
Long term power af 20w seems a bit low, imo I'd keep short term power at the same number as long term power so clock speeds dont bounce around so much
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
Question what do I do here? image.thumb.png.92bf4e2cfcf269e9a7cef628a04b7ab0.png
