Cables seen in white case
Agena_
Hi, does having a white case make cables more noticeable and make it look messy than a black case.
Thanks in advance
More noticeable? Yes.
More messy? Not nescecarily, in my opinion.
If your cables are neatly managed, I think cables can look just as good in a black vs. white case.
If you do value the looks of your system, a white motherboard does (in my opinion) make parts and cables more visible, which can be a good thing if you for example have a lots of RGB, pretty sleeved wires and good looking parts. Of course if you want to see all of that, is up to you.
I want to have a white build.
White ram, partly white mobo, stock amd cooler with white rgb, black gpu
I'm wondering whether a white case would make it look empty and messy
You could paint it black on the inside, but if you get a white motherboard, the contrast will make it stand out any way, and then your 'better off' with a all white case. The new define R7 black and white(on the inside), looks sick
Define_7_Sheetmetal_Black_White_wo_sidep
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
