Search In
  • More options...
Find results that contain...
Find results in...
Clicking sound coming headphones
Go to solution Solved by bulletrullen,
Hello, I have an issue with my headphones. I have a clicking sound coming from my dt 770s, when i hear the clicking sound, i unplug it, it's still there, for about 1-2 minutes. I think it's something with the 3.5 plug itself, though im not sure. But when I touch the tip of the plug the sound becomes louder, and if touch the beginning of the plug it only clicks in one side of the headphones. What could be the issue? Do you guys think it's fixable? Or should I just replace them? They are not that old, so i still have the warranty.
i finally solved it, it wasnt the headphones. the sound was made by my led spotlights.
just to confirm are you hearing sounds after unplugging the headphones off your source?
***FEEL FREE TO DM ME QUESTIONS ABOUT MY GEAR IF YOU HAVE ANY QUESTIONS OR JUST CURIOUS***
CPU : ryzen 3600x  Motherboard: msi mag b550 tomahawk RAM:16 GB ddr4 corsair lpx GPU: gtx 1070 6gb Case:phanteks p400
Storage:x1 280 gb kingston ssd x1 1tb WD blue hdd x1 2tb seagate barraccuda
 PSU:650 GQ Cooling:be quite! dark rock pro 4Keyboard:ducky one 2 rgb full sized Mouse:G502, Model o Operating System:win 10
Desktop audio gear: topping d10 --->  monolith Cavelli Liquid Spark---> Beyerdynamic dt 990 , Sennheiser Hd 58x, Hifiman HE4xx, AKG k240, AKG k52
Speaker Setup: Topping PA3--->Micca RB42
My portable setup: fiio Q1 mk2, fiio ubtr, fiio btr1k,fiio btr5---> whatever bud or IEM Im feeling that day
 AKG y50bt,Sennheiser HD 4.40
You might be staticly charged.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
yes but it happens when im not touching it too :/
yes
Newegg
