Limiting Speed for NVMe SSD with ASUS Hyper M.2x4 Card?
JohnSmith2
I have an Asus X99 Deluxe motherboard, and I currently have a Western Digital WD_Black SN750 NVMe SSD in its M.2 slot as a boot drive. I do lots of video encoding of lossless 4K video files (40GB+) which is primarily disk bottlenecked. I am considering purchasing a 2TB NVMe SSD to help, but I have some questions.
I would like to continue to use my existing WD NVMe as a boot drive. My motherboard came with an Asus "Hyper M.2 x4" card that I could use for a second NVMe drive.
  1. Are there certain kinds of M.2 NVMe SSDs that are not compatible with this motherboard (for example, Gen4)?
  2. Are there certain kinds of M.2 NVMe SSDs that are not compatible with this Hyper M.2 x4 card?
  3. Will the Hyper M.2 x4 card limit the transfer speeds compared to using the M.2 slot on the motherboard, or will read/write speeds be equivalent?
  4. The PCIEX16_1 and PCIEX16_3 slots are occupied by GPUs, making PCIEX4_1 and PCIEX16_4 unavailable. The motherboard manual says that the M.2 socket on the motherboard shares bandwidth with the PCIEX16_5 slot. Since the M.2 socket is only for the OS drive (occasional small random reads/writes as opposed to non-stop massive continuous reads/writes), I assume that wouldn't hinder the performance too much if I used the Hyper M.2 x4 card in the PCIEX16_5 slot. Am I correct in this assumption?
Here is a diagram of the motherboard PCI slots and other related info:
Hyper requires bifurcation, might want to read up on that procedure for the board first.
Are you sure? Any time I'm researching that I'm only seeing it in reference to Hyper M.2 cards that can hold multiple SSDs. This card can only hold one. It also came with the motherboard. I was more concerned about its compatibility with certain kinds of SSDs.
I assume you have the 40 PCIe lanes CPU in it.
1) no, the PCI-e is backward compatible, so any NVMe SSD should just work.
2) no, it's just PCI-e to M.2 adapter, it's not a controller, there's no microchips in it. so it will work with all M.2 NVMe SSD
3) if it's in PCI-e 3.0 x4 speed PCI-e slot, then no, it won't limit the transfer speeds
4) it mean that the bandwidth have to be split, or one of them have to be shut down. In 3.6.3 PCH Storage Configuration, it says that if PCIe_x16_5 in in x8 mode, the M.2 will be disable. and if the  PCIe_x16_5 in in x4 mode, the M.2 will be in x4 mode.
and yes, the Asus Hyper M.2 x4, just need the 4 lanes from PCIe_x16_5, so you are safe.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
no, that one doesn't needs it.
The HYPER M.2 X16 CARD needs it.
EXTERNAL
HDD/SSD :
Yes, I meant the ASUS Hyper with multiple NVMe sockets of course. Didn't catch the x4 as it's just a regular adapter.
Thanks. To make sure I understand correctly, what you're saying is that if I have the PCIe_x16_5 slot in x4 mode, then I could have an NVMe SSD in the motherboard's M.2 slot and another NVMe SSD in the Hyper M.2 x4 card in the PCIe_x16_5 slot without any performance bottlenecks, correct?
page 3-43 in instruction
i assume you have 40 pcie lanes CPU
EXTERNAL
HDD/SSD :
23 hours ago, NewMaxx said:
dual NVMe sockets of course.
it's quad M.2 NVMe socket, and to be honest, it's not like he really need bifurcation for it to work. even that HYPER M.2 X16 CARD would work, because he only need one SSD to work in it...
it's not worth it, but it will still work.
EXTERNAL
HDD/SSD :
Right, I meant dual if he intended to use x8 on that slot. (which is possible with a BIOS mod and the X16)
Yes, it is 40 pcie lanes (5960x). So x4 mode does not limit the performance of an M2 NVMe SSD over x8, right?
if it's in x8 mode, then M.2 is disable.
if it's in x4 mode, then M.2 is enable and at full x4 speed. (the M.2 is getting that 4 PCIe lanes fromn PCIe_x16_5 slot)
EXTERNAL
HDD/SSD :
Are there any M.2 drives that require more than x4? Or is x4 good enough for all M.2 NVMe SSDs?
the max for M.2 key M is 4 PCI lanes.  There are some SSD that have 8 lanes, and 16 lanes, but they all are just PCI-e SSD, or PCI-e RAID card with couples of M.2 SSD.
PCI-e 3.0 x4 is 32Gbps
PCI-e 4.0 x4 is 64Gbps
That's fast enough
EXTERNAL
HDD/SSD :
