Search In
  • More options...
Find results that contain...
Find results in...
7700k CPU bottleneck with 3080 RTX?
What are we talking about in terms of lost performance, namely %?
Debating getting a new CPU but for my budget (around 1000 USD for Mobo as well), it doesn't seem worth it according to UserBenchmark.
Only for gaming, 1440p.
Desktop: 7700k @ stock, 32gb ddr4 @ 3000, 1080Ti, Maximus IX Hero.
Laptop 1: Asus Zephyrus 701 - i7-9750h @ stock, 16gb ddr4 @ 2666, 2070 RTX
Laptop 2: Dell G3 15 - i7-8750h @ stock, 16gb ddr4 @ 2666, 1050Ti
Yep, even with rtx 3070, check Minute 10:00:
Thanks.
If I'm reading this correctly, 17% bottleneck?
5 minutes ago, Andreas Lilja said:
Thanks.
Yes around that, depending on the title.
21 minutes ago, Andreas Lilja said:
if i had to guess it's probably closer to 25% , i have a 8600k and it's not pretty.
9900k 1.3v avx 5.0avx 4.8 ring 95C 175w 1.05v 4.4ghz 95w 55C R20/blender temps ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-32-280-28 ddr3800  bdie 1.47v dram 1.22v io/sa (anything higher needs more voltage on all (dram/io/sa) ll EVGA 2080 ti XC 1995//7600 power limited 79C max, stock voltage (bad ocer) ll 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA G2 1300w ll Windows 10 Pro ll NEC PA272w (movie, work mon) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
old rig 8600k d15 evga 1080 ti hybrid  z370 extreme 4 2x8gb ddr3866 cl16 512gb nvme evo+ 860 evo 500gb raid 0 evga p2 1000w
1 minute ago, xg32 said:
if i had to guess it's probably closer to 25%, i have a 8600k and it's not pretty.
Aight. Eyeing the 10700k.
@Teddy07
@Teddy07
a 10600k with an overclock should heavily reduce any bottlenecking as well, though 10700k prices have fallen pretty far recently so both arent bad choices. with how expensive z490 boards are though, i'd consider an 8700k/9900k combo
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
@Teddy07
Unless you have an intel bias, zen 3 will likely squeeze the last bit of out of a 3080 over a 10700k, i'd sit on the 7700k for now and wait for benchmarks
considering theyre likely to be scarce just like the gpu releases (iirc 10600ks are still over msrp, and 10900ks too), intel isnt a terrible choice right now. itll be interesting to see how they stack up as youll get 2 less cores at each midrange price point (5600x vs 10700k/9900k, 5800x vs 10850k/10900k)
i'm watching 5600x vs 10700 very carefully, and 5950x SHOULD be the gaming king, can't wait.
i figure the 5950x will have thermal/boosting "issues" just like the 3950x, so that the lower core count skus still clock better. i wouldnt be surprised if theyre all the same like zen 2, or if the 5600x/5800x actually come out ahead due to the single ccx thing
Not a pressing matter, gonna wait for the 3080s to be available. Late November?
Isn't my ram slow for Ryzen? It's 3000mhz
3000->3600 is about 5%, not too much, but performance is the reason you are upgrading
Mostly RTX, other games work fine so far.
