Search In
  • More options...
Find results that contain...
Find results in...
Hey guys please if you have similar problem react on this :)
i have MSI MB B550 Tomahawk and iam installed the pantheks neon combo. Everything is fine except the female 3 pin connector. It’s so loose there is no connection between them. There is only one special point where it’s run and the neon it’s glowing. So from that I know there no problem else where only in the loose connection.
Do you have similar problem ? If so how do you fix it ?
Thanks for all recommendation :D
Those RGB connectors are literally hold on by friction of the pins, and plastic around it.
I'd just you black electrical tape or something...easily solution, and it won't make it stand out like a sore them (unless you want to use red or green tape or w/e).
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB Intel 660p NVMe
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
Intel Z97 Rig (Secondary)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
So there is no “clean” solution ? Just to find the right spot and do whatever it will hold the place ? 😀 it’s so common problem ?
