What should be the idle temp of a ryzen 3 3200g with stock cooler?
Solved by mariushm,
The processor will not care, as long as it's below around 80c
Most A lot of modern motherboards will automatically lower the fan speeds to make your computer more silent, while keeping the cpu temperature around 55-60c or lower.
Basically, if the cpu temperature is in that range (50-60c) they won't spin the fan faster to speed up cooling and keep the cpu even cooler.
So there's nothing to worry about.
